cucv 1008 np208 to np205 swap
jeepmkcomin
Wilmington, NC
I was thinking about swapping out engines to a sbc 350 and am worried about breaking the np208 so was thinking about swapping it for a np205. Does anyone know the output spline count on the th400 transmission? Is it short shaft or long shaft (1.5-2" stickout or 3-3.5" stickout)?
m16ty
218
Dickson,TN
I've done the 205 swap years ago but don't remember what's involved. I'd stay away from the 203. They're ok but arn't near as good as a 205 and you'll have full time 4X4 unless you install a kit to convert to part time. I personally think the 208 will hold up fine unless you're going to hop up the 350 or do some serious offroading.
11Echo
92
CT W. R.
I've been thinking of putting a late version 203,(with the improved gears/chain) I have in my 1008. It has the Specialized Automotive Engineering kit in it which I bought from Bob Chandler years ago. The 203 gives you the pto option that the 205 has and the 208 does not. The best part is I have the matching T400 also!
jeepmkcomin
Wilmington, NC
If I was going to put a 203 in I would have the option of a 203-205 doubler later on. It is an offroad only rig.
84cucv1ton: Thanks! I would appreciate it, can you measure how much shaft sticks out too?
hobie237
Newark, DE
I'm pretty sure it's a 32 spline as well, but I'm not going to swear to it. My buddy swapped a 205 into his truck and it was a direct swap. There are a few versions of the 205, I'd make sure that I got one with a PTO- even if you're not planning to use it immediately, it couldn't hurt to have it.
Mtrdrms
Torrington, CT
Why swap? Have you ever broken a 208? I personally have had good luck with them with big tires and big horsepower plus a lower low-range ratio than a 205.
hobie237
Newark, DE
The 205's low range isn't ideal, but it's a stronger, gear-drive case rather than the 208 chain drive case. The 208 is strong enough for most applications, but if he's planning a 350 with a lot of power, in extreme situations, you could outrun the capability of the 208.
