Uh, the U.S. Army?
Civilian K30 diesel has the same # of leaves as the M1008 and is actually rated at 9000 gvw (I have one and checked)i was wondering if a cucv m1008 has more leafs in there leaf spring pack than the civilian k30 what gives the cucv a 1 1/4 ton rating over te k30 1 ton rating??
Are those factory helper springs or aftermarket? I just bought a K30 that has 4 helper springs, but the leaf pack looks highly "rigged" as the bottom overload, as well as the 4 helpers, have all been crudely cut to length with an oxy/ace torch. I'm trying to rebuild the spring pack with another K30's, but want to make sure 1 helper is all that's really supposed to be there. I've never seen multiple factory helper springs before, and as far as I can tell, the helper spring stops are in the same location as my other K30 which only has 1 helper spring.The civilian K/V30 single rear wheel pickups have been rated from 8600 in 1977 up to 9200 gvw in 1987.
This pic is of the rear springs on my current 1988 V30 dually pickup.
