gimpyrobb
dumpsterlandingfromorbit!
- 27,786
- 770
- 113
- Cincy Ohio
I have been on the waitng list for one for a long time. They sent an email that they were available in limited numbers as of Fri 9am eastern.
Well to that I say, there's a large aftermarket support already in place dedicated to swapping 12 valves into ANYTHING. Including a complete bolt in kit for the 73-87 Chevy trucks. As of now you'd have to fab up everything from scratch for this new motor, including either a new trans, or an adapter. Not to mention the wiring Christmas tree involved with the new fangled stuff. Where as the 12 valve kit includes motor mounts & trans adapter for around $2000.00, and oh yeah the 12 valve only has 1 wire. Then there's the power factor, mildly modified 12v put out around 400HP at the turn of a screw. But I suppose if everybody wants to go with the new thing I say please do, more 12v's for meSometimes there is too many mods to fit an inline 6. Its not always about price, but it is often!
Advance Adapters has had their hands on these engines for awhile and has already come out with at least 1 trans adapter (check out the Dirt Every Day episodes with this engine). Engine comes with everything needed to make it run/operate. Have to figure out mounts, plumbing, intake/exhaust.Well to that I say, there's a large aftermarket support already in place dedicated to swapping 12 valves into ANYTHING. Including a complete bolt in kit for the 73-87 Chevy trucks. As of now you'd have to fab up everything from scratch for this new motor, including either a new trans, or an adapter. Not to mention the wiring Christmas tree involved with the new fangled stuff. Where as the 12 valve kit includes motor mounts & trans adapter for around $2000.00, and oh yeah the 12 valve only has 1 wire. Then there's the power factor, mildly modified 12v put out around 400HP at the turn of a screw. But I suppose if everybody wants to go with the new thing I say please do, more 12v's for me![]()
Agreed, sounds great for just what they're marketing it for JEEPS not CUCV's... OOPS but then there's the 4BT for jeepsAdvance Adapters has had their hands on these engines for awhile and has already come out with at least 1 trans adapter (check out the Dirt Every Day episodes with this engine). Engine comes with everything needed to make it run/operate. Have to figure out mounts, plumbing, intake/exhaust.
I like the 12 valve, but a 1000+ lb engine with that length doesn't fit/too heavy for most lighter trucks/suv's, and is not compatible with newer emission requirements.
The big picture point I'm trying to convey is that if your going to go through all the hassle & expense of doing a diesel engine swap. Why not get as much out of an end result from all that work & expense as possible? At the end of the day, if you did an honest comparison of 2 CUCV's (#1) with this new engine,... & (#2) with a 12 valve,... The 12 valve would come out on top in (power), (cost), (ease of installation), and (reliability).These same engines you're saying are too small for a pickup are used in medium duty vehicles. Main vehicles that used the 4bt and now 2.8 ISF? Box trucks like Fedex and UPS, which are a heavier weight class than these CUCV's.
The big picture point I'm trying to convey is that the 6bt ain't the best option in all aspects as you believe. Not as fuel efficient and more difficult to swap in. Just because a 12 valve is best in your opinion doesn't mean it's the best for everyone.The big picture point I'm trying to convey is that if your going to go through all the hassle & expense of doing a diesel engine swap. Why not get as much out of an end result from all that work & expense as possible? At the end of the day, if you did an honest comparison of 2 CUCV's (#1) with this new engine,... & (#2) with a 12 valve,... The 12 valve would come out on top in (power), (cost), (ease of installation), and (reliability).
