w5ood
- 19
- 8
- Houston / Texas
So the drive lights on the dash are not working. Everything else works fine in the dash cluster. All turn signals work, gen1 gen 2, high beam, 4x4 all lights turn on as they should except the drive lights that light up the speedometer and the fuel gauge and the voltmeter light. If I pull the cluster and apply 12v to the circuit they all work perfectly, except the voltmeter light since its not part of the dash cluster. So I am pretty sure its in the wire harness. PINS 2 and 11 on the plug that go into the dash are what connect to the drive light circuit. When I turn on the lights I would expect to get 12v at one of those pins, Is that the right way to trouble shoot the wire harness pins? Im a bit lost now that it seems to be an issue in the harness. Any advice would help just trying to figure out where to go next. thanks!
