vincentnova
- 2
- 3
- San Diego, CA
hi everyone
i have here a 1985 cucv that Im working on.
Im trying to understand few things here any help would be appreciate . thanks
question : with the engine off and with the shut off solenoid ON to let go the fuel in :
if you send fuel via ONLY an electric lift pump , does the fuel goes all the way up to the return port/line on the top cap of the db2 ?
or does the db2 pump has to rotate at the same time to have the fuel going all the way up to the return port/line?
thanks a lot
thanks a lot
