87-89 DUAL CIRCUIT MASTER CYLINDER BRACKET. (The only unavailable part needed to retrofit a single circuit deuce to a dual circuit 1987-89 Air Force truck style system)
(The below info is copied from the following post in order to keep relevant brake system material in a common "sticky" post.) https://www.steelsoldiers.com/showt...-temporarily&p=2068370&viewfull=1#post2068370
Well Clinto was able to obtain a new Dual Circuit Master Cylinder Bracket. We modeled it up in 3D CAD....and then ran out of time to put much additional effort into the project for the time being. We understand that this is a complex shape and not something likely to be easily duplicated at a cost inline with what most members are willing and able to pay. In an attempt to take advantage of the site's many members who may have creative ways to redesign this in a cost effective way and/or access to discounted manufacturing processes needed, we wanted to share what info we have put together so far (a digital CAD model of the factory bracket). So for you folks who have Fab skills, tools, and access to a CAD software; you can find the files on GRABCAD (a CAD fileshare site). The files are saved in a number of formats, but there are NO DRAWINGS, only 3D CAD files. The 3D files contain all the dimensioning needed.
Please note that the bracket was modeled exactly after the cast bracket. There is a "Simplified" version cad file of the bracket as well that has most of the fillets and drafts removed that are inherent to the cast design. The model should at least give proper dimensions and angles for those who undertake the challenge of redesigning this into an easier to fabricate weldment that will meet form, fit, and function of the original ductile iron casting.
The files can be found here:
https://grabcad.com/library/m35a2-du...nder-bracket-1
If anyone finds a good way to reproduce this, be sure to share pics of it!
View attachment 704598View attachment 704599View attachment 704600View attachment 704601View attachment 704602View attachment 704603View attachment 704604
