Rattlehead
- 3
- 18
- Michigan
I have gear lube in the knuckles. Pulled a lower kingpin bolt and it came out, need to replace the inner axle seals.
Am I looking at this seal correctly? It appears that the seal is trapped behind a machined surface in the axle, or is that part of the seal? The manual says there is a thrust washer, then the seal. But the thrust washer looks to be still on my axle shaft, however it does not want to come off easily, if it is the thrust washer. Just want to be sure before I start wailing on things.
Also, any suggestions on where to get this seal for a reasonable price?
