LiveFreeOrDieTryn2B
- 20
- 18
- Springfield AR
Ok guys I relocated my fuel pump any thoughts or concerns.
huh?I was hoping to keep the pump less prone while driving I can always change it back if it makes things worse.
Well there is that ! It is almost impossible to clean behind the baffles. But as far as moving the location of you pump, unless it was for a clearance problem or something along those lines all your doing is making more issues for yourself ie: moving the fuel lines and electrical wiring. Now you have another area for fuel to leak out of or something to get into your tank.I can change it back the new hole did make cleaning the tank easier so no biggie.
I got my pump out of the 109 without removing the tank... just have to rotate it a certain direction before trying to tip it out .One advantage it might be (for M109s anyway) is that you don't have to drop the tank to get the pump out. On an M109 there isn't enough space between the bed and the tank to get the pump clear out. You might be able to dissassemble the pump, but I didn't try that.
