yamabro
- 2
- 0
- Vanleer, Tn.
I know. But TexAndy is right. and water in the system just causes corrosion and then you've got failure.
this is most likely your problem they almost always leak.. i would switch back to regular pet cocks or 1/4 turn valves to fix that leak .. before i waist any of my time hunting down other possiblities..You probably need to adjust the air governor to .. but when you get done reading the tms on your truck you should have a good idea how to do thati have a quick release valve on the tanks on the one i am having trouble with.
come to think of it no i didnt maybe thats it .thanksDid you put any teflon paint or tape on the threads of new valves?
how do i fix. after sets over night its down to 30psi.
Now that may well be a fixable problem. That's very low. Probably functional, but not what it should be. Does the compressor cycle as it should, mostly off and just replenishing the air from time to time? Or does it run all the time? Do you get the "woosh-pop" when the governor drops the unloader line anywhere from ten minutes to a couple of hours after you park the truck?it never get above 80psi
thats the first thing i checked.You mentioned in post#8 not making over 80psi; check your belt. A loose belt can = low air pressure when running (I know from experience). like post#9 said you should be running at 100-120 psi.
First, let me claim NOT to be an expert. What I can say is that every single time I fix a leaky hydraulic/air system it breaks somewhere else with the "new" pressure until I have replaced every component in the chain. Might just be me. Just in case it's not though, the first thing I'd replace is your gauge. A good measurement is worth it's weight in gold. And of course, good luck!
