nk14zp
- 17
- 38
- Columbia Falls Maine
Deere starting fluid uses propane as the propellant .
roll the passenger window down, aim and push the start button with your toe, then spray.
I am running straight diesel and use a 1 second shot of starting fluid in the mushroom. I walk around and my deuce starts with about 3 to 5 seconds of cranking.
Well I have pressurized the fuel tank with shop air and opened the blessed on secondary till I got good fuel out. So I am sure the bowls are full. I also filled them with gas when I changed them on Sunday.If your intank pump isn't working then its possible you're filters are empty as well. Check them first, if empty fill them with (preferrably diesel) fuel.
