ivbeenrokd
- 1
- 0
- knoxville, tn.
I'm having running trouble with the deuce and wanted to see if anyone has any advice. This has gone on for several years being manageable in the past but has gotten progressively worse to where it's no longer manageable. It seems like it's getting air in the fuel system which causes it to cut out and even die at low RPM. It was horrible during the Knoxville Veteran's Day parade, died 6 times and has a hard time starting back until I bleed the air out again. It's had a fuel leak on the IP for a while so I thought that was the issue. Found the fuel leak to be the #2 line on the IP, fixed that Friday. After running it yesterday and today I've found that I still need to bleed air out before I start it (using the nut on top of the 2 secondary fuel filters) and it still dies. This seems to be worse in cold weather. I can bleed the air out, run it for an hour, and there's air in it again. I can run it, let it sit for a day, and there's air in it again. I haven't found any other leaks in addition to the one I fixed Friday. Any ideas?
Thanks,
John
Thanks,
John
