kc8sfq
- 0
- 0
- Southern Mich.
Howdy y'all:
It's been a bit of an adventure getting here. First, someone else had the audacity to already have my favorite username. Then we had a problem with cookies (I prefer chocolate chip). Anyway, the fine moderator here got me squared away and It looks like I can post now.
First: I've been reading here for a while. and have already found some treasures of wisdom. Now that I can post, I hope to contribute some treasures of my own.
Second: I have a fair bit of experience with M-37s (I've put over 80K on mine) and a bit of experience with M-35 series duces and M-274 mules. If I can help with those, I'd be glad to. I'm located in southern Mich. and can probably be of some help with road trip rescues. At some time, I'll figure out how to post myself on the map, but that's a project for another day.
Now to the reason for this long winded introduction:
My duce, actually an M-292 expando, is pumping engine oil from the injector pump area. Is this a common problem? Any suggestions would be appreciated. I have determined that the 40 year old lube oil hose is still holding pressure, up to 80 PSI. I have not yet pulled the elbow fittings to test those. I expect however, that the likely-hood of a cracked fitting is probably lower than a leaking seal in the 40 year old pump. i'm not looking forward to pulling the pump. Actually, pulling it is the easy part. Getting it back on (with the right timing) is the scarry part. If I have to do that, I expect to have to pull the sheet metal on the whole front corner.
Thanks in advance: KC8SFQ
