Deuce lighting/harness upgrade
AN/ARC186
15
Graham,Washington
Well, it must have something to do with my engineering background in the aerospace industry...I happen to admire the engineering that went into building these vehicles and try not to add shabby parts or compromise the original design goals. Other than that, I have no comment.
The relays in my system are used to reduce the circuit breaker load within the 3-lever housing, a separte breaker is supplying the head lights and the 3-lever switch serves its function as before.
I'm with you on this, all the additional 24 and 12 v essential and non essential bus systems I've installed on the deuce are energized through aviation relays, (those big ol blue potter brumsfields) all controlled through aviation grade switches. haven't ever had a problem. boy, they really did brainwash us AE's good......
