G-Force
- 8
- 18
- allendale nj
I was leaning more towards timing due to your lack of power but after reading this article
Heavy Duty Technology: Piston Failure Analysis: Engine Builder
I would look at your piston cooling nozzles for proper installation and aiming. You also said you had damage in #1 cylinder and you believed it was passed over from #3. it could be you were having another failure in that cylinder. You made a statement that both these cylinders are at TDC at the same time. This is not true. When #1 is at TDC #6 is at TDC' This is what is called companion cylinders. In other words the pistons for these two clyinders are in the same location in their respective cylinders at the same time due to the crankshaft. While one is on its compression stroke the other is on exhaust stroke. So it would be 1-6, 5-2, 3-4. what does the pisotn crown on #1 loook like? Judging from the looks of the valves in the heads for #1 and #3 they both were overheating.
