Heres something I saw on ebay. I'm sure they must be made and available from Napa or somewhere onshore, These probably are chineese, I believe a company call Deitz made these at one time, hopefully still. But painted camo and installed as back-up lights, these would look close to something military sort-of. Problem is, their 12V and also 100W. In a serries, do you run 24V posative into one light then the negative to the posative of the next light and the negative of the second light to frame or whatever your useing as a ground ? and then will 24V be split into two 12V with both lights in this serries? If you could use these (in a serries) they would be neat in a couple different locations to the sides as well as driving lights for offroad
