chevycrawler
- 0
- 0
- Sayville, New York
I have an m1008 with a 6.2L i want to put the 6.6L LB7 in it, is their a kit or can i just swap them and get a new harness?
The Izuzu diesel makes a lot more hp than the 6.2 or 6.5 GM diesel does. You would have to replace the transmission and transfer case or it will suffer an enrly demise.I have an m1008 with a 6.2L i want to put the 6.6L LB7 in it, is their a kit or can i just swap them and get a new harness?
You would be better off getting a second engine and then rebuilding it. This way you can still use your truck while the rebuild is taking place.where can i go to build my 6.2 then?
An M1008 is a CUCV, basic 3/4-1 ton pick-up truck. If you fins a way to shoe horn a DT-466 into one of these, please post pics.chevycrawler,
Have you explored option to install IHC motor?
I think DT466 will fit very nicely. If DT466 is not available DT360 is not bad ether.
You can buy one of this out of school bus for about $1,500 - $2,500. And if you choose earlier then 1994 no electronics needed. You also going to need a plate to fit from your SAE2 bell housing to your trany. I guess $500 or so.
DT466 can pull up to 300 HP 600 Lb/ft @2,000 RPM without changing parts just tune it correctly. Up to 600HP upgrading turbo + adjustments. If you are picky, for about $5,000 upgrades your can reach limit about 1,400 HP.
DT360 is the little brother. Smaller dimensions. It has almost the same (-10%) potentials.
Think about.
Never heard of one, do you have a link to one built factory w/ a cummins....
