- 1,117
- 1,054
- 113
- Perry, FL
What is the best way to restrain the door to keep it from hitting the mirror when opening?
There should be a tab that goes into the cab that hooks to the door in the center of the hinge that will keep it from young too far out. If this is an issue. You can remove it thru the fresh air kick door, remove the arm and add washers to the inside of it that will fit over the door side of the arm but not the hook on the fresh air door area and reinstall it so it will stop the door sooner.What is the best way to restrain the door to keep it from hitting the mirror when opening?
All I need pics of is the mirror and the door's hinge area(in between the hinges specifically) on the inside of the jamb.
I bought extra rubber bushings and doubled them up. Keeps the door from hitting and keeps it bit more closed for ease of closing.Door stop:
The hole side goes on the door with a cotter pin, the bumper part goes in the cab as described earlier.
