Downloadable Manuals for Mighty Mite M422 / M422A1
BigBlock65
Houston, Texas
Here is a download link to my library of Mighty Mite M422 and M422A1 manuals in PDF format:
https://docs.google.com/leaf?id=0Bz-n7H ... l&hl=en_US
So far, I have these seven posted:
TM 9-2320-225-10 Operators Manual
TM 9-2320-225-20 ORGANIZATIONAL MAINTENANCE Manual
TM 9-2320-225-35 FIELD AND DEPOT MAINTENANCE Manual
TM 9-2805-217-35 Engine and clutch, AMC AV-108-4
TM 9-2520-237-35 Transmission and transfer assembly, New Process model 4300
TM 9-2520-242-35 Differential assemblies, Spicer model 27
SL-4-00882A USMC Stock List, Repair Parts List
Most have been updated to the latest M422A1 revisions, including published changes.
I have assembled these manuals from the best copies of the latest publications that I have been able to find.
They are not copy protected, so you can edit them in the future if you want.
I corrected the page numbers, made them searchable, indexed the text, created bookmarks, corrected page orentation for viewing, and cleaned up anything that I could.
There are online vendors currently selling CDs with old and incomplete copies of these manuals.
I recommend that everybody compare these copies against what you currently have to make sure that you have the newest information available when working on your Mite.
I hope that these manuals help you with you Mite projects.
If you find anything missing from these versions, or if you find anything newer or of better quality, please let me know.
I will add more as I find them.
I am currently looking for the following:
TM 9-2910-208-35 Holley carburetor, model 1904-F
TM 9-2910-209-35 AC fuel pump, Type EP
TM 9-2920-214-35 Delco-Remy generator, model 1117495
TM 9-2920-215-35 Auto-Lite starter, model MCZ-4001-UT
TM 9-2920-216-35 Auto-Lite distributor, model EO-14428UT
TM 9-2851 Painting Instructions for Field Use
Please let me know if you know where a paper or electronic copy of any of these can be obtained.
Marv hoebing
Quincy IL
Thanks for getting back to me I may the wrong year of unit but what I have is 4 cylinder oppoes in mighty mite may be a AMC engine they used in Vietnam may be 1967 this a air cooled engine
Marv hoebing
Quincy IL
Thanks for the info I guess I am not seeing the manual for the air cooled engine in my mite looking for firing order cylinder number placement weather number one cylinder is on left are right side
