Dual 12 / 24 volt alternator on M932A2
BrushMaster Builder
Killeen, Texas
Yes, I've installed the CE Niehoff 200 Amp 12/24 on two M939 (with Armored Cab) repowers I did a few years back for the National Guard. We had to build a beefy support bracket to hold that bad boy.....heres a picDSCF0053.jpg
162tcat
46
Washington
Brushmaster, what intercooler are you using in front of the radiator? Is that a stock m939 radiator? What other application, if any, is that intercooler used on?
BrushMaster Builder
Killeen, Texas
The radiator and CAC in the picture is the same cooling package in a Marine Corps 7-Ton MTVR manufactured by Modine. That cooling package, in the MTVR, supports a C13 Cat and a 4700 Allison. In my repower I was using a Cummins ISL and 3500 RDS Allison. Needless to say....that cooling package had no trouble with the Cummins and Allison. More is always better..........
juanprado
2,899
Metairie/La (N'awlins)
Thanks for sharing the info and the pictures! Keep them coming!
Are the front brakes upgraded? I see a 3rd hose? Can you tell us more.
4,795
Another option would be a battery equalizer. I picked one up for my SEMTT project that supports up to 50 amps for $125 shipped off ebay.
1,129
jelfert
Church Point, LA
My dual volt alternator has a 8 groove pulley. What is the correct belt to use? I've read that it will need to be longer than the stock one.
w3azel
Waipahu/HI
Ok so I'm about to purchase one of these dual voltage alts for my truck. I don't know much about these types of things but I just want to get something cleared up before I start wiring. Everything shares the same ground correct? I don't need to wire a second ground separate from the vehicles current one for the 14v system?
CPDOG
24
SEABECK WASHINGTON
hello from Seattle
I have been communicating with a rep from Niehoff about ordering the 1505 and he sent me the actual blueprints and I have been doing some base line dimension checks and so forth., but has anyone actually installed one yet? if anyone has, please send me an email if you would. and maybe some pics.
my main concern is it a drop in replacement or will there be some fabricating of different brackets involved?
I thank all of you for the inputs and look fwd to reading them.
juanprado
2,899
I am looking at adding a n1511 dual 12v & 24v 100 amp off a lmtv to a nhc250 m923. From what I can see so far the double ear will mount on the bottom but definitely need a new top bracket fabricated for the top mount. A double pulley looks ok to mount on the front shaft. I am concerned the voltage regulator might not clear the oil cooler. I have not yet tried to mount it.
