MArch 1st, 2009.
In West Virginia the deuces used for logging work usually got fitted with Goodyear G177's M+S 1100R20's on singles flipped rear hubs. Our experience off road was that the duals tend to "float" on deep mud and snow, and won't deliver as substantial bite to move the truck. If you have a flat with a singled deuce, yeah, you have a problem, if you have a flat on a dualled deuce, not so bad, but still a problem that needs attention now.
if you flip the rear hubs, the track is not as wide as the dualled rear end, but the side slope mobility can't be that much different if the load's where it should be in the bed.... and you may be able to squeeze through places that the dualls might get caught in or not pass through.
The duals were probably used due to the tire technology of 1948 not being able to offer the margin of safety on singles that our radials do today. The Goodyear G177's 1100R20 s have a higher tire weight capacity in singles then the NDT pair they replaced.
Uncle seems to like the singles on the M35A3's, and you can get them 95% remaining tread life for about $100.00 each.... what's not to love? Better traction, fewer tires to replace.
Last thought, run your NDT's on ice, rain, or snow on pavement, if you want a religious experience, I can just about guarantee you'll get one!
Cheers,
Sincerely,
Kyle F. McGrogan
