- 2,569
- 2,233
- 113
- Efland, NC
In anticipation of the upcoming snow/sleet/ice event predicted for central NC on Friday, I decided to give the MEP1030s a test run. I wanted to see how the new heatpump worked while on generator power. Had no problems with the heatpump. One thing that did surprise me is when the heatpump comes out of a power failure, it ramps the compressor to full power which according to my power monitor is around 4.9kw. Along with the base load of the house that cam to 5.2kw on the display of the 1030. It handled it fine. This is an inverter based heatpump so it normally only runs the compressor and fans at a level that is required to maintain the heating/cooling load.
Graph of the energy demand from the heatpump:
But that did make me think that if my wife flushes and kicks on the water pump when the heatpump is at full blast, that might be a bit too much for a single unit. Well... These are supposed to parallel and I just happen to have 2 of them.
Unit 2 has entered the chat!
Took an extra cord that I wasn't using and connected the two generators together and gave that a go. Seemed to go very smoothly. The procedure to get them synced up was just a couple of button presses. It seemed much to easy to be honest. No complaints though. Easy is nice, especially if you are operating under stress.
I'm expecting since I spent the afternoon getting all this ready that NOTHING will happen!
And that's all right with me.
Hope everyone in the path of this thing stays warm and dry!
