I have just acquired a ECU/Genset trailer. The NSN it was sold under is 8340-01-459-4352 but there are no legible ID tags to be found on the machine itself, so that is subject to govplanet's accuracy level. It is powered by a Lister Petter engine and mounted on a hmmwv era trailer. I believe we saw a 1999 mfg date somewhere, but I can't find it again now.
The genset seems to be operating correctly. The ECU was said to be 'drained' of refrigerant. The power light illuminates but it will not run the fans or compressor or heater. We have opened the control box and found the magnetic starters. If you push each of the starters in manually, the appropriate component runs. At this point we stopped to attempt to find necessary documentation or advice. I returned and started to trace the control wires to the mag starters in the control box, and they appear to go to a circular 8 pin socket labeled PSR which appears to have a component missing.
pics attached
pics attached
