Why would you want a "Computer Dash" that is likely made from proprietary components, with questionable life and serviceability?
Good points and wouldn't want one myself. Didn't post for myself though... I don't even have an ECU so it's no value to me... Posted it for others whom may like the idea.
Now if I did have a ECU only thing that would make me consider it is if it was was more than just gauge replacement... and that appears to be the case with these folk...... which is main reason pointed it out as an opportunity if one is inclined that way.... Seems they offer not only ECU and TCU info, but also, EGT's,
mapping!!!, solar charges, tanks (water, grey, black, propane) etc. can all be added to the same screen right in good visual position of the pilot. Also apparently they offer output to your own laptop instead of a screen.... for pilot or copilot.... wherever you want to place it.
As to quality and proprietary.... good points... no clue. But then again.... like they say... one should never ASSUME right.
