EGT harness question
ldmack3
1,740
N. Central Idaho
There are several feet of extra wire tied up behind the dash for the EGT. Is this length critical for impedance matching or can I take out the extra?
runk
66
Houston, TX
The wire is likely special thermocouple wire. Any cuts will need to be welded with no filler metals, or crimped with special thermocouple connectors, matching the specific thermocouple type. Other splices or changes will change the level of the temperature signal outside the range of the gauge.
I'd leave it alone.
runk
66
Houston, TX
And re-reading the post, specifically the length of the wire doesn't make any practical difference. (unless you're getting into the 100's of feet range)
So, if there is a re-useable connection on the back of the gauge, you could probably shorten the wire there.
Charlie175
409
VA 22849
I made the mistake on mine by ordering it extra length. Didn't need the extra length so I have it coiled up.
