portert0224
- 0
- 0
- West Point, VA
Ok, I've followed the -20 and -30 and cannot seem to get any power when the key is turned to the run or start position. Any "new" advice is greatly appreciated. Here is the history.
Truck started at Lejeune auction site. Drove it 5 1/2 hours back to Virginia with no problems. Have been driving it daily 20-50 miles per day for about a month.
Last Sat, my daughter started it and drove it about 1/4 mile and it just stopped running. No unusual noises or warnings in advance, just stopped running while she was driving down the road. From that point on, I cannot get any power from the key "run" or "start" position. None of the usual buzzers or warning lights when turned to the run position and nothing when turned to the start position (no wait light, glow plug selenoid clunk, etc) that we know we are supposed to get when the key is turned .
Followed the -20 trouble shooting. Checked all under dash fuses first--all good. Did not see any burnt fusible links or wires on the firewall. The truck has 24 volts at the batteries, 24 volts at the selenoid, no lose wires on the starter or selenoid. Replaced the starter relay--did not fix the problem..
Followed the -30 and replaced the starter switch on top of the steering--didn't fix the problem.
When I was replacing the starter switch, I noticed that about 1" below the connector, there was a red wire that had the plastic covering rubbed through from contact over the years with the dash frame. It wasn't melted or burned, but did show signs of arcing, so I cut this out (maybe 1/4" of length) and I crimped in a connector and finished replacing the starter switch.
I totally disassembled the entire instrument panel and cleaned everything up. I removed all of the lights, cleaned them up and checked them for continuity--they were all good. I cleaned all of the copper connections on the instrument circuit board with vinegar and a Q-tip. I reconnected the instrument panel (it looks like new now) and reconnected the instrument panel connector to test the key cylinder to see if I got any buzzers or lights when I turned the key to the on position. Nothing. I turned the key to the start position and nothing.
I really don't have a clue as to wear to proceed from here. It seems that the problem is not between the starter switch and fuse box, or there would have been a blown ignition fuse. It doesn't seem to be a problem between the selenoid and starter relay because it has voltage at the selenoid switch and I replaced the starter relay.
Anybody ever had a similar problem? Is it possible that the starter IS bad and somehow completes the circult at the switch? Anybody know what the red wire going from the starter switch (looks like it goes behind the fuse box and I presumed this to go into the 30 amp ignition switch fuse)?
I loathe the thought of having to tow it into Mr. Goodwrench if I can't fix it myself. I can only imagine the bill for "troubleshooting" this vehicle.
Thanks in advance,
Tracy
Thanks in advance,
Tracy
