HitchMar Films
- 3
- 8
- Bullhead City, Arizona
Hey Everyone,
I've made two other posts on this problem and everyone has come back with some great ideas and suggestions... Sadly, nothing has worked....
Problem; No headlights, tail lights, or rear side marker lights. I have turn signals and brake lights, until I turn on the turn signal, my brake lights go away. The brake lights come back when I turn the turn signal off.
Attempted Solutions; Swapped out the 3 lever light switch with a new NOS one. Same problem. Checked the dimmer switch, appears to functioning correctly. Believing it is a ground loop problem, checked all the grounds/connections. They appear to be good grounds. Checked all the bulbs, they appear to be good also....
Question; Can a bad turn signal module effect my headlights?
Thanks again everyone!!!
Chris...
Chris...
