Engine air compressor gasket
Csm Davis
402
Hattiesburg, Mississippi
I actually changed the head out with a different one and made sure that it was flat. And it blew out in a different place this time. This is a common problem as I have changed many over the years, I believe that the head design is weak between the bolts and over time they warp and or crack.
Csm Davis
402
Ended up putting a thick almost like asbestos gasket back in and left extra around the outside will trim it down to about 1/8th around the outside. But on the bright side I now have everything you need to cut gaskets.
gimpyrobb
dumpsterlandingfromorbit!
27,786
765
Cincy Ohio
Which gasket sheet did you use? I was wondering if the high heat gasket material might work better. I know they sell sheets of it for exhaust stuff.
