Engine Stall
54
XENIA OHIO
I just brought my m1028 home after 71 days of waiting for EUC. the only problem i have is ,when you rev the engine up some and let up on the petal
it will stall , what problem do i have.
2,758
Could be the idle is set too low. I think there is a dashpot on the throttle that holds the throttle a bit off idle during decel. Someone else with more CUCV knowledge will chime in. Could also be dirty dieselgas filters. Service it and see what happens.
bigmike
355
Dixon CA.
Be sure you have fresh diesel. My M818 wanted to stall each time I let off the pedal. I added some lucas to the tank and a fresh tank full of diesel and it went away quickly.
54
XENIA OHIO
thank for all the help . i have put in fresh fuel with lucas additive in it.
I have a new filter to put in it ,just need time hope this clears up my problem .
