Ether vs. Liquid Wrench?
rumplecat
221
North West Arkansas
My M1008 is hard starting when it is cold, I don't like ether starter fluids even on small engines. But from what I am reading some folks swear by Liquid Wrench Silicone spray saying it will not harm the engine any experiences, I need some type of safe alternative to ether.
Nonotagain
41
Parkville, MD
My local Advance Auto Parts store sells starting fluid with an oil additive.
If you are going to use something like Liquid Wrench, you might be better off using WD-40 since it's not as thin and will lugbricate the cylinder walls in addition to being very flammable.
You can also purchase engine fogger intended for long tern storage of marine engines.
rumplecat
221
North West Arkansas
From what I have read the flammability of ether is the problem in diesel engines creating too much force through combustion. I already add outboard motor oil to help with lubricity, I need something to give that little boost on cold starts with out the explosion of ether.
Nonotagain
41
Parkville, MD
Ether is a lot more explosive than Liquid Wrench or WD-40. I'm guessing that the detonation of the fluid isn't nearly as violent as ether.
I used ether, hair spray and WD-40 in my potato gun and the ether was the most explosive of the three products.
I had no flame out of the barrel from ether, just a slight blue/yellow flame from the hair spray and a three foot long trail from the WD-40.
ralbelt
9
West Warwick, R.I.
I keep a can of silicone spray in the truck. Only had to use it once about a year ago. Ether and glow plugs is a bad combination, disable GP's if you must use it.
Silicone is recommended here and by my neighbor who is a 30 year diesel tech.
derby
10
S.E. MI.
I have used a rag lightly soaked with gas with good results. It is better to have a helper to do this. You do not get the violent knocking.
Ether is ok if you can meter it, just spraying it in the snorkel, well You know.......
I don't use ether unless it is an emergency.
Doesn't it have any type of block heater?
chevyCUCV
Massachusetts
Glow plugs are a good option to any type of spray
Sorry had too, the 6.2 can start fine even under -20 Fahrenheit. Sounds like something is wrong gps, or cranking speed.
doghead
4 Star General /Moderator
1,179
NY
There is a big difference with the effectiveness of ether with an direct or indirect injection diesel. Ether is great when used correctly on direct inj engines.
This topic have been covered in depth before.
