gonorth
- 0
- 6
- Rochester, MN
nk14zp, something wacky going on there, a month in BC is not normal. I would call GL as ask them for some advice or at least a number in BC for you to call
Mbsk01, 11 days in BC based on it being Wednesday now probably includes 4 weekend days, so I am guessing you are at 7 now. You should have it by tomorrow.
Mkcoen, I think yours is the exception to the rule. Lucky you. Maybe your name is the same as someone that is on one of their 'lists'. Orf you moved recently or you used a cell phone number that is harder to match to a physical address, or you are in a state where you don't need to update the address on your DL after moveing and that doesn't match, or whatever. I think the EUC reviewers are assigned by region. Maybe the Texas region is under staffed. Are others in Texas seeing slow processing in GL? Whatever the isssue is your are doing the right things by talking to them about it. Your clock is ticking and by talking and going thru GL you at least have good reason for ending up with a late approval.
