Two quick questions:
1) (First question has two parts) a) I bled the brakes and it was not incredibly hard. Tedious, sure, but not hard. The back left wheel had an issue where no fluid came out when I loosened the bleeding screw 1 full revolution. I continued, and it finally started coming out the sides on revolution 2 or 3, but certainly not down the middle where the bleeding tube goes. I'm thinking that the screw is faulty. True/false? b) Also, the middle right wheel did not have any fluid come out. At all. I took the screw all the way out. To check the pressure, I tried the master cylender and fluid came out just fine. My question is can I get this to the shop so they can take a look with the brakes in this condition?
2) Does the fuel filter look OK? From pictures I've seen on the interweb, I'm not sure if it is missing the bottom part or not. See attached picture.
