So my failsafe warning control module (FWCM) has been driving me insane
trying to repair. The initial complaint was the Low Air Warning light was
not coming on. I tested the 2 Low Air switches and all was well. So I threw
in a used but new to me FWCM and everything WORKED!
Days pass, truck sits.
I go out to the truck and SAME ISSUE, the low air light inop.
I replaced both low air warning switches and threw in ANOTHER
used but new to me FWCM, ALL WORKS!
I go out to the truck and SAME ISSUE except now the parking
brake light is inop too! ( the buzzer always works thru all this) .
I reach down and wiggle the FWCM and dam if the low air warning light
and parking brake light didn't flash for a second! BINGO! I think I have
a connection problem at the screw on FWCM plug.
(All the while I am sure the ground is afixed to one of the two FWCM bolts)
So I pull the FWCM off the wall and get some slack in the wire harness that
feeds the FWCM and I look inside the plug and it looks like one of
the female connectors is pulled out a tad.
This plug has a ring that connects the plug to the FWCM, then above
that there is another ring that you can unscrew, what comes apart
next? I can not find a how to in the TM's.
STOP THE PRESS'S OH MAN.................
I was just outside dinking around w/ it and I pulled the ground and
THE LIGHTS CAME ON but the buzzer sound volumn went down 50%.
If I attach the ground the lights go OUT and the buzzer rings loud!
I am totally lost here...
