Small Prepper
- 2
- 8
- Gernantown, MD
Morning
In my 1985 M1009 I have noticed that the high idle is not working. (when I start it up hot or cold weather)
I went and looked at the fast idle solenoid and found that the shaft in the solenoid was about an 1/2 off the fuel throttle bracket. (not running, cold engine)
I started the truck and the solenoid engaged and almost touched the fuel throttle bracket. I pulled the wire off to test the solenoid when running and it worked fine. (the shaft dose adjust with an screw driver. I check that)
Questions : Any reason that would loosen up or would someone back it out so it will not work?
The main Question is : What is the adjustment (how close) should the shaft be from the fuel throttle bracket?
I looked in the TM's and found alot of stuff but not the adjustment setting. (Still working my way throw the TM's)
Thanks S.P.
Thanks S.P.
