Thanks for the suggestions so far Guys. I don't care if the are non MIL seats I picked up an aluminum flat top 42 inch sleeper and plan to notch out the rear of the cab to allow a walk thru , air suspend it and the rear of the cab , then move the batteries in to the sleeper and install multi seating and leave the two stack bunks, Going to fab a custom headache / chain/binder rack and incorporate the already complete rotating hoist lift , , evaluating options for spare. I hadn't thought of the air ride box GOOD suggestion. Ill incorporate it ! Sleeper has a rear entry hatch so iam looking to SQUEEZE a small folding stair in on the side and Squeeze in thru the rear as well. Plan to do a custom aluminum sheet center console between the drivers and co drivers seats that will still allow a walk thru. Replace the current soft top with a Plate steel permanent roof and integrated gun ring. Have been completing small things so far , truck only has 4000 since overhaul , mostly air valves and switches , runs well, was going to turn up power BUT I think I am happy with it the way it is , plenty of grunt and enough HP for my needs with an 18500 k lb fifth wheel, Trans modulates well. Added LED ten inch back up light. Low range reverse lock out linkage, repaired the CITS and the anti lock brakes, Added main power lock out, keyed ignition and door locks, air cleaner up grade . Any other suggestions are appriciated Wife wants some nice leather Captains seats ( you know the adage Happy wife , happy life ) Was looking at a block heater , but started just fine at 14 below today. and it will spend its next life ini the desert south west
