Finally got a Deuce!!!
rmgill
14
Decatur, Ga
would those 1100's work as singles?
Never mind, 7,390lbs in single configuration. 2 would hold up the whole truck empty. 6 are 44,000 lbs rated. Hmm.
bigburb
Chickasha OK
Yea when I got the truck I had planned on running singles. Hence me only making a deal on 14 tires instead of the 22 total he had (4 with considerable wear). I didn't think I could fit them as duals but after a test fit they went on but there is evidence of a bit of rubbing on the rear axle where the cap is that holds the large rod below the springs but it looks to have only done it once or twice. Also the gap between the rears is about a 1 3/4 but thats at sixty psi and no load. We will have to see later because I plan on using the truck to pull my debris gooseneck trailer in New Orleans as soon as I get it ready.
