Fire Extinguisher bracket bolts
DTL
Bakersfield, CA
Does anyone know the bolt thread size for the fire extinguisher bracket on the floor of these trucks?? My oh8 didn't come with an extinguisher, but I'd like to use the stock floor plate to mount the one I just bought. None of the leftover junk I have in my bolt box seems to fit though. Help!!
DTL
Bakersfield, CA
I will. I've got a tap and die kit somewhere (I just moved) that would be a big help. Maybe I can uncover it before I make it to the hardware store.
DTL
Bakersfield, CA
After some trial and error, it turns out the extinguisher bracket takes 8-32 hardware. I tried mounting the new extinguisher I bought with these size bolts and I have NO confidence in their holding ability. The hardware is far too small. I'll be welding some new studs to the floor bracket and mounting the extunguisher that way. Last thing I want is a 10lb fire extinguisher breaking loose and slamming around the pedal box.
319
Lieutenant
57
Michigan
That floor bracket is not meant for a 10lb extinguisher. It's meant for a 2.5lb, NSN 4210-00-889-2221.
That's not to say you can't try to mount a 5lb or a 10lb there, but I wouldn't.
319
Lieutenant
57
Michigan
10lb was the smallest I could find with a metal head.
I had my 5lb mounted on the lower backside of the "B" pillar on the passenger side. Out of the way and still accessible. No longer have it so I can't post a photo.
