1stDeuce
- 15
- 18
- Farmington, NM
Ok, I didn't see too much on the subject, so I'll ask... I run WMO in my deuce a lot, and when the weather turns cold, I end up significantly reducing the concentration to get the flame heater to work. (Or I end up shooting it with either...)
Anybody put a separate fuel reservoir on the truck to run straight #2 diesel in the manifold flame heater?? It has it's own pump, so it would seem like it's simple to just feed that pump from a small tank. Might even mix in a bit of gas to make it ignite better. ?? Wouldn't hardly have to have any volume, as you're only running the heater for a few seconds until the engine starts. (Bjorn proved that the turbo snuffs out the flame once started, right?)
What are your thoughts?? This might let me run closer to 50% all year long, and elminiate the either starts, which always seem hard on stuff...
C
C
