I am finally getting around to fixing a leaky wheel cyllinder on the rear axle.
Of course I cannot fix anything without breaking something else in the process.
While removing the brake line from the cylinder, I tweaked the line and it sheared at the fitting.
I would like to cut the line clean, put it into the fitting, and reflare it - BUT I do not know what to use to flare the end.
How do I flare the end? What do I use? Is this something I should be doing at all - or should I just be sourcing an entire hard line?
Pic attached.
Pic attached.
