Mark Thomsen
- 0
- 1
- Layton, UT
Has anyone had trouble changing the v-belts on a FLU419? I can get the loader hydraulic pump belt off but can't find a way to fit the belts between the cooling fan and the power steering pump pulley. I am hoping I don't have to pull the loader, radiator, and then install a 3/16" or so spacer between the fan and the crank pulley to create a 3/8" gap to fit the belt through.
I am hoping someone out there can tell me what secret is. It is bad enough to loosen the power steering pump tensioner bolt but I have a system now and that isn't really that bad in comparison to getting the radiator out of the way to put in a spacer.
My driving force is that the water pump pulley is loose and I have no more adjustment so a new belt is necessary.
Thanks,
Mark
Thanks,
Mark
