It helps a great deal and it looks like other than the hydraulic power there's a Cannon plug with 12 volt power going to it.
I talked to a shop today and they recommended I set it up with the pto setup. He said he can convert it to a direct flange Mount or stick with the driveshaft depending on how much room is in there. The pump is going to be about 500 bucks I'm still going to look to see if I can find a military pump with the drive shaft
Don't overlook an important point...this system requires a variable displacement piston (or some vanes) pump, pressure compensated, and is not a positive displacement (gear) type pump. Unless that OEM pump comes from an FMTV or HEMTT, it ain't gonna work. I'll grab the pad and go take a photo of mine for the next post.
