- 629
- 22
- 18
- Port orchard, WA
Does anyone know or has anyone tried these??? I may have found a supplier if these will work.
View attachment 722835View attachment 722836View attachment 722837View attachment 722838
I would want to verify verify a bunch of things first. Width of the wheel flanges (come in 2 different widths, the wide which matches our axle width has low speed gears, the narrow has highspeed gears). spring perch center to center (these have a different width) you will need mrap rims. Will the center section offset cause interference. The center chunks are different, ours are round these are ovalish. Will require custom steering components as arm setup is different. These axles have air lockers, true planetary at the hub(high wear). Housings are cast steel. If you have a strong fabrication background, welding equipment, money and a way to move these things around, go for it. They do offer 45 degree steering, which may or may not rub as well.
