epartsman
- 0
- 0
- Jacksonville/Florida
Water is the best as some of the solvents in store brand flushes can cause more harm then good if not totally removed from the system after using. Also remember after refilling the radiator to add some anti cavitation corrosion inhibitor which will extend the life of your cooling system. You will need to find a non a/c pickup as most civy blazers had a/c and they are different. Now would be a good time if you are thinking about adding A/C to acquire a factory A/c case however remember you will be starting down a Mod road like the one I am on which will require fabrication. I have already located a civy K10 p/u diesel with all of the A/C still intact that I will be installing in mine that will require 1 battery to be relocated, firewall cut, the bus bars moved, and some dash fab as well as a custom alt/a/c comp dual mount bracket which I will be fabricating on my own.
