HardCorps79
- 3
- 0
- Kansas City, MO
Okay, so I got under the truck to check out my popping steering. Steering box "looks" okay. But all my rubber is shot- ball-joints, shock/steering damper bushings, etc. is all literally crumbling. I can move them all with just a little hand pressure.
I've been planning a good refurb of the truck for a while now, just waiting to get the dough, ya know. So here's the plan for the front end and my rough estimate parts cost. Let me know if I'm missing something, or if you have any suggestions and potential pitfalls I should avoid.
-Upper ball joints $65/pair
-Lower ball joints $$80/pair
-Wheel bearings (inner & outer) $30 each side
-Inner tie rod ends $100 for both sides
-Outer tie rod ends $100 for both sides
-Pitman arm $35
-Steering Box frame reinforcement kit $130
-Steering Damper $30
-Shocks $80 (pair)
-U-joints $80 (all around)
Total of about $800.
I'm also gonna change the glow plugs, and do fluids all around.
And rear wheel bearings.
Window felts/rubber as well. Haven't priced this yet.
Am I missing anything?
Call me nuts for dumping about a grand into this, but I only paid around $2.5k, with very little rust and 50k miles. Most of the bubba-job K5's in the area with over 100k on the engines are going around $5k. Figure I'm doing alright.
Again, any thoughts and suggestions are welcome.
(With my luck, in the next few weeks the tranny will blow or I'll encounter the gov-bomb will be SOL with my plans.
-Pitman arm $35
-Shocks $80 (pair)
