Fuel check valve HELP.
edpdx
75
Oregon
I've had a leak the past few days with fuel drain back. I spotted dripping from the stock Stanadyne fuel base- right from the bottom. The bottom filter bail is warped and only the passenger side of the lower bail applies pressure to the filter to remain tightly seated.
I have a new 1/2" fuel check valve with 3/8" tapered hose fittings on either end; I want to install the valve to be sure the pump remains primed. I am not sure how or what line it would be spliced into.
Please chime in if you can help.
diesel583
N E Okla.
You don't need the check valve if the system is air tight. Think of your fuel system as a hydraulic brake system no leaks. Replace the filter base.
corvette9
new haven ct
I put mine in the feed line under the truck. On the Rt side of the frame there is a steel cover at the back of the cab. There are rubber lines under that cover. I just put it in the rubber line and put the cover back on. Works perfect. The truck can sit for weeks and never lose prime. Best 17.00 I ever spent.
edpdx
75
Oregon
RESOLVED: I ordered the F100W filter from PUREPRO to change out my stock BOX filter because it was leaking out the bottom and running down the FIW hose. At first I assumed it was the sensor and that I would need to "plug the hole" if I wanted to keep it stock. I thought it had to be the base because it hadn't been leaking, and the filter (FRAM) was only 2 months old. Anyway, before undertaking the filter change- I'm tight on time this week, I went to NAPA and bought the WIX GOLD. TADA. No Leak.
Funny thing is I received the Spin-on order, it was messed up- no one's fault, really. I called them, and they said a new one is on it's way no charge. Now I have two, and the original is staying put. :shrugs:
Thanks for all help.
