Fuel filter o ring help
jlpayne
Vale, NC
Greetings,
I am embarrassed to ask this, buuuuut. Dang I can not get the o rings in for the fuel filters? Mmwhat is the trick? It's like they are just a bit to small and I don't want to rip them, what do you guys do?
ageregunner
88
Breinigsville, PA
I have not had any real trouble installing those o-rings. I just push around with my finger, then I inspect with a mirror before securing the cannister. Perhaps you have the wrong o-rings.
jatonka
90
Ephratah, New York
The primary fuel filter gasket is Napa 5131. The secondary fuel filter gaskets are Napa 5070. These are good correct numbers, I buy them 100 at a time from WIX who makes them for Napa. The Wix numbers are 15131 and 15070respectively. JT
arno
Bavaria, Germany
I installed the WIX 33511 as primary and 33512 as secondary & final. The seals are a bit too small, so I stretched them a bit by placing it over the engine oil filter canister for a couple of minutes... (I was in need of a new seal because the old one was already very brittle...)
Greets
Arno
m715mike
3,884
Montgomery, Texas
I attempted to replace my fuel filters today (original style filter in the canisters). I purchased NAPA Gold filters from fleetfilter.com and attempted to use the gaskets that came with the new filters. After reading this thread and a couple others, I now know I was using the wrong size gasket.
I got lucky with the primary filter. It sealed nicely on my second attempt. The original gasket was still good on the secondary filter, and I reused it. However, I had no luck with the final filter. Looks like I'm headed to NAPA for a 5070 gasket.
Once again, I am very appreciative that someone asked a question (the OP in this tread) and several others replied with useful information! Thank you!
Tracer
14,266
Hawthorne, NV.
Just changed my fuel filters with NAPA Gold filters and used the gaskets that came with them. Usually I have more trouble getting the old gaskets out. Coat the new gaskets with a little oil and use your fingers to install.
Katavic918
54
Maryland
I used Napa #3511 and 3512. I also had trouble with the o-rings. I guess I used the wrong ones also. They fit perfect except for the rings.
Mrmag1
Head of Stuff N' Things
14
Hereford Arizona
Ok dumb question but are all the other ones rings useless that cone with it? My secondary filters I got from big Mike's has the napas in the bag and other ones that I guess are the right ones to use. Also in the Napa bag is 3 other orings and such that where not in the filters when I took em out. I figure they are for other applications for different vehicles.... I wrong?
gimpyrobb
dumpsterlandingfromorbit!
27,786
769
Cincy Ohio
I have correct usgi filters with the correct gaskets for $5 each plus shipping. No guess work on the O rings. PM if interested.
