mooresM35A2
- 0
- 16
- Madison County IL
The cckw 352 I just got is having some issues. Ill start from the beginning. Got it home and it started running like a dog. Wanting to fall on its face when you go to take off and dying when you let it idle for about five minutes but it would start somewhat easily. I should mention that when I went to look at the truck it started perfectly and ran down the road without a single hickup so go figure. Truck also has a new/rebuilt Zenith carb on it. The gas tank had some old gas and alot of custy rust and debris in the tank so I took it out and let it sit with some evaporust in it, steamed it out really well, put everything back together and now I cant get any fuel up to the carb. Filter in the filter bowl is gone, has an inline filter right before the carb. If you take the line going to the carb loose after cranking there is air pressure built up there like there is a restriction in the carb or something. Not sure if this is a common problem with an easy fix.
