pidgeon
- 0
- 0
- Portland, OR
A few weeks back, my power steering belt broke (ahhh yes... nothing is more fun than steering and breaking a very heavy, exceptionally quick brick without power steering...) I drove it home and replaced all of the belts. Yes, I know... this shouldn't have anything to do with starter relays, but bear with me here..
Immediately after getting the truck (which has been thusly dubbed "Soilent Green" by the neighbors) back on the road, I notice my voltmeter is staying in the yellow. Hrmmm. I make a mental note to check on it and somehow forget. Which brings me to this morning.....
I go to start her up. Glowplug light on. Gen2 light on... no gen1.... weird. I turn the key. Click click click from the relay cluster under the dash. I use the other car, stop at napa on the way home (because, hey, Gen1 light is burnt... might be the issue..) and swap the bulb. Click Click Click....
Out comes the voltmeter. 30.1 across both batteries. I go and try it again. I turn the key and leave it on glow plug. Gen1 and Gen2 come on. I get out and look under the hood real quick and hear a different *click*click*, this time at the relay right on the firewall on the drivers side behind the aircleaner. 3 clicks and stop.
So, now, as I dive into the TM wiring diagrams to figure out what the **** is going on, so I can fix it (and since I'm there install the doghead relay mod, since I'm paranoid as all get out about frying expensive to fix things), I humbly ask the MV gods and goddesses "WTF?"
In other words.... any ideas on where I should start? I've searched the forums and have a few clues (voltmeter relay is my main suspect), but, I'm always open for expertise.
-beth
PS. back to the power steering belt... I checked all my connections on the alts... they seem fine. I checked to see if the flailing belt took out anything.... if it did, i'm not seeing it. 30v across makes me think that all is fine from the alt side of things and that is is a relay thing either caused by a spike from my belts, lots of wet PNW weather or old age....
-beth
