61sleepercab
- 3
- 0
- Walton, West Virginia
My 1982 VW Rabbit with mechanical injector pump manual stated that you could run up to 20% gasoline to 80% diesel mix in winter.
Modern gasoline goes bad in about 60 days, a friends dirt tract car would not even start on six month old pump gasoline. I would not try running junk yard gas in a modern fuel injected car.
A friend used to work in the local oil refinery laboratory and i asked "why does today's gas go to gum and varnish in no time?" He replied," older gas was run once through the distillation column and you pulled off what gasoline you got, now heavy compounds are treated and cracked into lighter compounds, AND WHAT IS CRACKED DOES NOT ALWAYS STAY CRACKED!"
Anybody pulled apart a carburetor run on unleaded gas lately? See any green looking stuff in the castings, bowls ?? It is ALGAE growing in the alcohol water mix in the gas. Carb cleaner will not touch it....... Use Dawn dish detergent. Isnt saving the planet with these new fuels fun? Mark
