Gasser gaskets?
cbvet
20
Northwest (Knox) Indiana
Anyone know a source for engine gaskets for Deuce gassers?
Need valve cover gaskets right now for 2 trucks. I know I could make them or use RTV, I'd just rather get originals.
Memphis & Saturn don't have them.
Eric
CBVET
badgmc56
Southington Ct.
I would use a good quality RTV. Ford makes a RTV used to seal oil pans on diesel motors that I have used for years that is the best I have seen. I just went through this with my 302 in my M-211. I bought an oil pan set still in the package and when I opened it , the gaskets just fell apart. I'm glad they did because I would have been doing that job over again in a few months. Most of the gaskets that you buy for those old gassers are original ones that are over fifty years old unless you can find some from NAPA which is a hit and miss game.The only drawback of using RTV is it is harder to disassemble which makes it a pain when adjusting valves. I just take my time and work my way around the cover with a sharp putty knife.
Barrman
1,782
Giddings, Texas
I bought a valve cover gasket a month or so ago from Antelope Valley. It was shipped folded over. I let it sit out in the sun for a day to get nice and flat. Then I used 3M weather strip (The yellow stuff) to glue it to the valve cover. I don't glue to the engine so it will come off easy and might be used again if I am carefull. I have about 500 miles since then and no leaks of any kind.
JasonS
144
Eastern SD
I bought some silicone sheet off of ebay and cut my own using an original gasket as a pattern. Doesn't leak and is reusable.
