combatmech
- 5
- 38
- Carrollton, Texas
Howdy all,
I'm still having some electrical issues.
Both alternators have been re-worked, checked good and autozone. batteries check good at 12.3v prior to starting.
Cranks right up, Gen 1 light stays on, Gen 2 light goes out.
Measured voltage at front battery. Shows rapid discharge.
Checked voltage from Gen1...40 plus volts. ( flux from 40 to 55v )
Checked back battery voltage...12.2
Checked Gen2 output 14v
Checked voltage at positive and negative bus bars....fluxing...couldnt get a good reading.
Just to try something different...I unhooked the slave plug wires thar go to the bus bars. Hooked battery wires back up and gave it a shot. Truck wouldnt start...got a click from the starter but no crank.
Is the slave plug wiring really required to be hooked up?? Or can the whole thing be removed?
My voltmeter has not EVER worked.
Is it possible that something is wired backwards???
Very confused.....
Very confused.....
